cv680 engine starts then dies
jimallen2012
My cub cadet 23hp (cv680) engine starts easy and runs only about 2 seconds. Will start right back up and again die after about 2 seconds. I have checked the fuel pump and it seems to be working. I washed the mower and engine. It was running good before I washed it.
Oil pressure switch wet maybe, causing it to think it doesn't have proper oil pressure.
jimallen2012
Hi ILENGINE.
After looking around quiet a while, I found that the connector to the key/starter switch was loose.
Thank you for replying.
Thanks for letting us know what the problem was. most people don't
