Customer strikes again
Hammermechanicman
Community Leader
Location
Southwest ohio
1000007871.jpgcustomer replaced P&C on a Dolmar 7900. They cranked the cylinder down with the bolts and used a ratchet to crank over the engine.....half way. Had to drive out piston with a hammer and punch. Ignorance is bliss.
Nothing beats a "Can Do" attitude with no experience.
looks to me that the ring is installed upside down, not fitting the pin properly and jamming it out into the bore. Not a lot of pistons have that feature.
Yup. He installed the ring upside down. Most every chainsaw has some way to locate the rings so the don't hang a ring in a port.
Almost every two stroke has the pin unless the ports are miniscule and even then...hell, .21ci RC engines have the pin.
