RaginMad55
- Mar 18, 2018
- 3
- 4
Hi I have a Cub cadet xt1 lt 42” with a Kohler ks540 engine. When I cleaned the outer engine with carb cleaner I sprayed a little at the air filter intake and now it doesn’t run right. Keeps running really rough even after it should have cleared out the carb cleaner. Did I really screw it up or is there something else I need to be checking out?
