ehobbs duffer
- Jun 18, 2016
- 12
When using the "Tank," when cranked, the engine runs just great. Turn on the PTO and it will gradually drag the engine down. Turn the PTO off and it will run just fine. If you're on almost non-existent grass, it will run until it reaches a little higher grass or an incline, then drags the engine down. This machine has performed great for several years. Now this!! Any suggestions?
