Cub Cadet LTX1045 Deck Springs
SpringGuy12
Hello,
I took apart my Cub Cadet LTX 1045's deck and in doing so removed the springs, and I cannot remember where they go. If someone could please explain, or maybe us MS-Paint to draw lines where these springs rightfully belong, I would be very thankful.
I have attached 3 images, one of the deck, and two of the respective springs.
Thanks for your time.
BlazNT
This looks like the logical placement to me.
SpringGuy12
I was certain that was one placement for the spring that is below the mower. I'm not sure where the other one goes though. Any ideas?
Look for shiny spots that look like something was hooked there. Possible location for the spring could be the S on the rod between the left spindle brake and the idler arm. Then the other end would hook back toward were the engagement cable plastic thing connects in that area.
bbowes
I am having the same problem. Would someone please be so kind as to post a pic of the location of the springs.
DenaSheppard
This was very helpful. Mother and I have a cub cadet and we are pretty good at figuring out mechanical issues...with the replys to SpringGuy12...this was very helpfuland we were able to get the yard mowed. Thank you
