Cub Cadet LTX1040 wiring for a B&S 33s877-0019-g1
pmccreanor
I have a Cub Cadet LTX1040 (2010 model year) and am replacing the original Kohler Courage 19 with a B&S 33s877-0019-g1. I have the mechanical part done and could use some help with the wiring.
Here are my notes on the wiring. I'm a little color blind so the green wires could be gray. The B&S has plug has orange, red, black, and green wires. The original Kohler Courage plug has blue, white, green, red, and a jumper wire. The Cub Cadet side of the plug has 2xred, white, 2x red with white stripe, and black wires. The original wiring connections (Cub Cadet (CC) to Kohler Courage(KC)) were as follows
CC 2x red/white strip --> KH blue
CC white ------------------> KH white
CC 2x red -----------------> KH red
CC black ------------------> KH green
There is a yellow jumper wire on the KH plug that goes from CC 2x Red/KH Red to an unused plug.
The Kohler Courage has gravity feed fueling while the B&S has a fuel pump. I would like to power the fuel pump if possible.
Any help is appreciated. Thanks in advance for you time!
