Tannersnoo
- May 2, 2019
- 8
Easiest way to check the coil is to fit a pair of red spark testers to the plugs then go mow.
When the engine refuses to start have a look at the testers.
If they are flashing the coils are good/
A couple of customers who are into show cars ended up fitting flashing plug caps which of course do the same thing.
ALthough my first thoughts would be heat expanding the pump housing just enough to prevent the pump working properly.
You might be able to fit a rubbing block on the end of the pump lever rather than bending it more.
What’s the red spark tester? It’s a single cylinder so by plug it connects in line and lights up if there’s spark? Or? Thx.
