cranks like it has something holdig it
noluck
my brioggs will only turn eighth of turn and drain battery am i missing a swich its a cub cadet 1000 and briggs 18 hp
Sounds like the old classic valve adjustment........
First of all is your battery charged ???? Can you jump start it from another battery and it will start ????
Let us know Mon Ami ~!~!
Flintmotorsports
a easy way to tell if it is the valves turn the motor over by hand past compression and try starting it up with a charged battery. if it cranks and starts up it is the valves.
jarnhold
I found out the hard way, rebuilding my 20hp when it was the battery the whole time, (**&%$%^%$^
Before you start, pull the spark plug & try to rotate the engine by hand.
No use checking the electrics if you have a hydraulic lock, seized engine or jambed belt overloading the stater motor.
Assuming the engine turns freely by hand, try cranking it.
Turns over freely without the spark plug = valve lash too wide or decompressor broken.
Adjust valve lash to .004" replace plugs & try again.
Motor won't rotate = new camshaft required.
Assuming the cam & valves tested OK you are then left with the electrics.
I like to start from the starter motor and go backwards .
Do the following 5 tests, regardless of the results from an or all of them as there can be more than one problem and you want to isolate where the problem lies.
Elimination of individual parts is important so you know by the end, the battery, solenoid & heavy power circuits are all in good order.
1) try to jump the starter motor directly from your car or truck.
+ on the starter first then - to a good ground near the starter ( drain plug or lift hook are good )
Starter turns = starter good
2) do the same directly from the mowers battery
Starter turns = mower battery good
No turn = duff battery, recharge it & try again.
3) check for voltage ( + 12V ) at the solenoid trigger wire with the key in start position
3a) same with ground trigger wire ( 4 wire solenoid ) or body of solenoid ( 3 wire solenoid)
( I like to test V from the battery hot terminal to ground terminal rather than ohms as they give funny readings )
4) leave ground jumper in place ( from step 2 ) & try key start.
Starter turns = power connection good but ground connection suspect ( most common )
Confirm it by trying again, extra ground removed
5) Remove the trigger ( thin ) wire / wires from the solenoid.
Ground one on a 4 wire solenoid & bridge from the hot terminal to the other.
Starter cranks = solenoid good.
Solenoid is not polarity sensitive, BUT THE WIRING IS so make sure you remove the thin control wires.
Note a thinner wire on the hot terminal is not a control wire. It is the main power feed to the mower.
From here on things become very mower dependant as starting circuits are getting changed all the time.
Basically the power goes in a loop from the hot side of the solenoid ( saves wire, no other reason ) through the fuse to the B terminal on the key switch then to the PTO switch then to the parking brake switch then to the solenoid trigger switch , easy peasy after you grow the 3rd arm. Use a test lamp and follow the power.
However a lot of mowers with a 4 pole solenoid, run a secondary ground control circuit to the ground solenoid wire through the lap bars.
Then to stop this interfearing with the normal safety function of the ground kill, it goes to a relay with the ground as the switched connection.
These are a PIA as the + control wire to the relay comes from the power loop above and the ground side of the control comes via the normal cut out functions of the lap bars.
Be very careful because if you have a system like this and accidentally send 12V down the ground loop you can fry the magnetos on some circuits.nd from the grounding bolt to one of the starter mounting bolts & paint over both with liquid electrical tape.
Tinkerer200
"my brioggs will only turn eighth of turn and drain battery"
This statement bothers me. Holding the starter engaged more than a few seconds at a time repeatedly causes overheating of the starter windings and a lose of wire resistance and thus lose of torque. Destroys the starter in other words.
Walt Conner
