Craftsman transaxle question
JoeNoble
Do mower transaxles have fluid inside them like car transmissions do? For some reason my is hard as hell to shift and I can't figure out why.
KennyV
Yes they do and there are several different types of trans-axles...
Some have actual gears some have variable pulleys... some are hydro drive.
What type do you have?
You also need to lube any linkage and pivot point. :smile:KennyV
reynoldston
could someone of put the wrong oil in it?
JoeNoble
No idea which mine is but the mower is a craftsman model # 917270630
Your trans has a flowable grease in it. A little thicker than 00 snapper grease but on the same priciple.
JoeNoble
So where do I get said grease?
Available through any poulan service center. I didn't see many places when searching online but the Dana/Spicer part number is 4300. Poulan has there own part number for it also.
JoeNoble
So what exactly is flowable grease? Wikipedia doesn't seem to know.
JoeNoble
Is there an acceptable substitute that can be found at an auto parts store?
SONOFADOCKER
Take the battery out from under the seat and the plastic battery tray - you should see a yellow top fill port fitting .
