craftsman t210 will not start
ACF
have a craftsman t210 model 13b0a1zs093 with kohler engine ks540-3011 will not start battery good, tested solenoid tested good fuse good. any clues to where to go from here in order to get it running thanks
Auto Doc's
Does it crank but not start, or not crank over at all?
ACF
no crank does nothing
Auto Doc's
Try arcing across the starter solenoid and see if it will crank over that way. If it does, there is a clutch or seat safety switch problem. If it has an electric PTO switch, sit on the seat, turn the key on, then pull and push the knob and listen for the electric clutch to click.
If nothing still works, check all connections under the backside of the dash.
From there you will need a multi-meter and a test light to do some circuit testing to find the issue.
Auto Doc's
Try arcing across the starter solenoid and see if it will crank over that way. If it does, there is a clutch or seat safety switch problem. If it has an electric PTO switch, sit on the seat pull, turn the key on and push the knob and listen for the electric clutch to click.
