Craftsman riding mower
MamaEspy
I have 2009 riding mower, have had no problems then all of a sudden it does not want to move, the belt had come off. When the belt was put back on it would not shift gears while running. Any ideas?
KennyV
Hello and Welcome to LMF, from another Kansan....
Check your belt path, you may have missed an idler pulley along the way...
Usually when a belt comes off, there is a reason... check to see that all pulleys & idlers turn freely and that all are in line... also check for missing or bent belt guides/guards..
If you don't find the problem, post back with the model # and someone may have an exact place to look... :smile:KennyV
Briana
Hey there - WELCOME to LMF! :smile:
I moved your thread to the Craftsman Forum. You'll get a better response there. :thumbsup:
