Need to replace rear axle seal. How do I replace the leaked transmission fluid.
T Talltree Member Joined May 6, 2023 Threads 5 Messages 15 Oct 14, 2023 / craftsman pro series 8400 model 247.204450 #1 Need to replace rear axle seal. How do I replace the leaked transmission fluid.
StarTech Lawn Royalty Joined Feb 19, 2020 Threads 107 Messages 12,081 Oct 14, 2023 / craftsman pro series 8400 model 247.204450 #2 You should access the fill plug after removing the battery and probably the transaxle fan. Note these fill plugs do go bad so have a replacement on hand before attemptingto remove the current plug. And when done install the new plug.
T Talltree Member Joined May 6, 2023 Threads 5 Messages 15 Oct 14, 2023 / craftsman pro series 8400 model 247.204450 #3 where is fig. 2
StarTech Lawn Royalty Joined Feb 19, 2020 Threads 107 Messages 12,081 Oct 14, 2023 / craftsman pro series 8400 model 247.204450 #4 Okay if you want go the more expensive route.
