craftsman model cmxqwas020890 3000 psi pressure washer
jotchy
  • / craftsman model cmxqwas020890 3000 psi pressure washer
Hi Man I sure hopr someone can help me out here. My pressure washer has a wierdly wired on/off switch. It literally just turned 2 and out of warranty while i was out of town on a family emergency. the problem is is it wont start. There is a white wire near the on/off switch that is attached to nothing and I believe it is the problem. Can someone please tell me where it goes? it is a briggs and stratton engine
Looks like a low oil level shutdown switch setup Everything looks wired correctly other than the on/off switch needs to be on I to start.
Try disconnecting the black lead to the little silver box then try to start.
