Lawnranger
yea it mighta been a bluish white smoke & it does smell a bit like oil/gas...i cant see how it could water in it its garage kept so it never gets wet....& just went out to & smelled the oil dipstick & DOES smell like gas...how hard is it to fix the float/needle valve problem?
As far as smell goes, it would have a very strong gasoline smell not just a little but that is subject to one's sense of smell. Usually if the float/needle & seat are leaking the oil level is way, way overfull but in your case the oil level is low so that leads me to believe your problem is oil consumption.
Perform a fresh oil/filter change and bring the oil level to just under the full mark and start the engine for at least 30 seconds. Shut the engine off and wait at least two hours. Come back and check the oil level. Add oil, if necessary, to bring the oil level exactly to the full mark. Take your time and add just a little bit at a time to ensure the level is right on full. Use the mower as usual and check the oil level before each use. If your engine is consuming oil the level will drop from the full mark according to how severe the usage problem is.
The above test make take some time but it's worth it. If an engine gets enough oil in the combustion chamber it will not perform properly and will puff bluish/white smoke out the exhaust. Next, we'll have to determine why your engine is using oil. You may also have a fuel/carburetor problem so let's see what happens after the fresh oil change.
