Craftsman LT 1000 is not getting fire to the plug
myke_t
I have a Craftsman LT 1000 that is not getting fire to the plug. It has the Kohler 17 HP engine. If the ignitiuon coil is good and I disconnect the ground wire on the ignition coil shouldn't I get fire then? I have sanded the coil and the magneto and tried a new plug.
If you pulled the kill wire from the coil and still no spark, replace the coil.
