Craftsman Edger Model #247.772460 (also, 25B-554D099)
hgoodwiniii
  • / Craftsman Edger Model #247.772460 (also, 25B-554D099)
Hi everyone, I'm a new member. Thanks for the add.
I have a craftsman edger (#247.772460) with Briggs & Stratton engine #10T802 0711 B1. I am able to start it after putting a new carburetor diaphragm and gasket.
My problem is that it won't stay running and stalls out. I can get it to stay running if I manually move the throttle shaft but as soon as I release it.
The throttle shaft is getting no action from the linkage and does not move when the engine is running even though everything is connected. It only moves if I move it manually.
Any ideas on this? Is this some kind of electrically driven throttle? Is there a throttle adjustment somewhere?
Thanks.
hgoodwiniii
I will go back and double check to make sure. Thanks for the link.
