Craftsman Eager 1 push mower
ring3
I have a Craftsman Eager1 push mower, 4HP/20", Model # 917.386020. The motor is a Tecumseh Model # 143.964008.
The mower either would not start or would run for a little while then stall. I cleaned out the carb a few times with limited success. I now have the carb off and have soaked it cleaner.
Could someone help me with the carb rebuild part number and the best place to get one? I would like the works, including; bowl gasket, gaskets, primer bulb.
Thanks.
Rob
Intake pipe gasket is tecumseh 26756 or oregon 49-402.
carb mount gasket is tecumseh 34690a or oregon 49-156.
air cleaner mount gasket is tecumseh 34338
primer bulb is tecumseh 632694 or oregon 49-231.
carb kit is tecumseh 632760b oregon is available but i have had issues with the aftermarket kits from oregon and stens with the needle valve not sealing, probably a seat problem. the oem kit may not be available in your area but if you can find it that is the one to use.
ring3
Thanks! I'm checking around for someone who has all the parts available. Hope to have this one mowing soon.
