craftsman 917.377131 height adjustment
mikehouse
I'm getting it wrong I guess.If I lets say,on the right front wheel push the heigt adjusment lever to my right,going away from the mower,it lowers the deck,resulting in a higher cut? Naturally doing the same on the other side and opposite direction for the back?
BlazNT
Lower the deck the shorter the cut. Raise the deck and higher the cut.
Manual:
searspartsdirect.com/partsdirect/user-manuals/917377131-craftsman-parts-gas%2C+walk+behind+lawnmower-manual?pathRender=fromManualTabPage&manualIndex=0
mikehouse
Thanks.I thought that also,but I had or read otherwise.Man,u all over the place.Keep up the good works.
BlazNT
I just read then answer as much as I can. I am in no way the largest contributor on here either. But I love it.
