craftsman 7.0 wont start
Mr.Gonzalez
hello ,
i have 247.389180 model
crafstman 7.0 platinum mower
it was running fine 4 weeks ago . cutting the grass no problems .
then try to start her again . no go .
she would only start up with starting fluid and would turn off once the starting fluid was burnt up .
so i change the gas to 93 octane and change the oil and check the plug and clean the plug and check the gap at .30
i had also check the float and carb . sprayed carb cleaning in all the jets and ports
im confused what to do next
any and all help is welcomed
and want to thank yall in advance
