Craftsman 6.0
you have a fuel restriction between the fuel tank and the carb needle. No you need to find out if it is the rubber seats swelled, or something in the fuel inlet, or the hose or fuel filter in the tank is clogged.
Thanks. I am just done with this thing now. I've wasted a week of my life trying to fix this thing.
Well I'd start by removing your tank and give it a good flush, for a couple bucks get some new line and an inline filter. Then you can focus on the carb
Remove your tank , fill with 1/4 gas, shake hard, dump out the larger fill hole, repeat until your happy
