Hi,
I have a Craftsman 19.5 hp. ride-on mower. I was cutting my lawn, today, and all was working perfectly until, suddenly, my blades stopped. The mower kept going as normal, no noises to worry about, but no blades rotating.
I stopped and released the handle that engages the blades (manual clutch). As I released the handle there was a sharp quick noise coming from the clutch area. I tried to engage the blades a few times after this and found each time that it made that same loud noise as I released the handle to dis-engage the blades.
Do you think the clutch unit is gone or is there something else causing this? If the clutch is gone, is it a big job to fix it?
Thank You,
Tom.
Thank You,
Tom.
