Craftsman 14.5 42'' cut Model 917.270514
smileyspaint
hi , my friend has a rider and it stuck in second gear . it starts and moves but only in second gear can you help ? Thanks Dale
Does the shifter move or is it also stuck. Could be that the shift linkage is rusted where it goes into the case or maybe a shift key is broke inside.
smileyspaint
the shifter is stuck . it starts when clutch pushed in. it moves in second but stuck .
Thanks Dale
Shift rod were it goes into the tranny is probably rusted and will need a lot of penetrating oil and some force to move it back and forth to free it up.
