jono252525
- Sep 7, 2017
- 9
- 42
Craftsman 5000 Watt Generator, hard Starting when Hot. Engine Tecumseh model HM100
Start in 2 pull when cold and Run Perfect even at 6500 watt ( Peak time) ,but if you stop it to refuel , it take about 10 pull before it start.
The Carburator is all clean and adjusted (ultrasonic) , the valve are good .008 intake .012 ex , new head gasket, Governor
adjusted, air filter clean, the spark plug look like new J17 LM.
I need your help.
I need your help.
