Counterweight links
bartles
Working on a 31C707-0154-E1
What is the allowable clearance between the links and the crankshaft?
Thanks in advance,
bartles
You have two sets of measurements.
The eccentrics are Standard 2.2045" (55.99mm) with reject size of 2.202" (53.93mm)
And counter weight links being Standard 2.207" (56.05 mm) with a reject size of 2.210 in. (56.13 mm)
So it can be anywhere from .0025" up to .008" depending on the combined wear. So anything .008 and over is definitely in the reject zone.
