Any ideas it doesn't move forward or back
A Atm96 Forum Newbie Joined Sep 8, 2012 Threads 3 Messages 6 Nov 5, 2012 / Coronet hydro wont move #1 Any ideas it doesn't move forward or back
Carscw Lawn Pro Joined Aug 11, 2011 Threads 66 Messages 6,375 Nov 5, 2012 / Coronet hydro wont move #2 Going to need a lot more info. Start with a model number. What was it doing before it stopped moving Sent from my iPhone using LMF
A Atm96 Forum Newbie Joined Sep 8, 2012 Threads 3 Messages 6 Nov 5, 2012 / Coronet hydro wont move #3 Model 1692130 coronet hydro 12 it runs fine but doesn't move I got it like that
Mwh0428 Well-Known Member Joined Dec 19, 2011 Threads 41 Messages 164 Nov 12, 2012 / Coronet hydro wont move #4 Check the drive belt if you haven't already. It could be a check valve in the hydro itself. Sent from my droid 4 using LMF
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 61 Messages 15,519 Nov 12, 2012 / Coronet hydro wont move #5 These two websites might help. http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=heCBEN8aqGZrE4Cxc5kbp796Dq http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=ifDzFO9buH2sF7Dyd6lEP5NRQpe As previous poster said, check the belt and towing lever first.
