L lestro Member Nov 18, 2017 #1 anyone know what the rod to crank go- no go clearance is on a 44r877-0001g1? going to use a plastigauge. thanks
Boobala Lawn Pro Nov 18, 2017 #2 I'm NOT completely sure if YOUR engine in this group but you can check.. http://www.smallenginesuppliers.com...iggs/common_specs_for_intek_vtwin_engines.pdf scroll down on pages
