I replaced the engine on my old Dixie Chopper with a new B & S Commercial Turf 25hp engine. For my residential use only mowing 4-5 acres. Do these engines hold up well? Any special care to help longevity?
Keep ALL the filters CLEAN, oil FULL, and annually remove engine shroud to clean out the cooling fins, GOOD Maintenance is the key to a dependable machine, oil & filters are cheap compared to O/H or replacement costs of another engine, I change my fuel filter TWICE a year, carburetors are USUALLY the most problems with lawn mower engines, IF you work on the machine, be sure to take tons of pics, (especially any springs - cables - BOTH ends ! ) the pics become your re-assembly manual...:thumbsup:
also.... take pics of the machines information plates or stickers ( Make-Model Seril numbers, for if & when you need to order parts or get help with Maint. see EXAMPLES
