Cleaning a 42 inch stamped lawn tractor deck?
Rickcin
I’m guessing the best way to keep the deck clean is to buy a front end lift and scrape it manually after each 2nd or 3rd use?
is this best and what would be the least expensive front end lift? I’m guessing those plastic tip ramps are useless? Thanks
Engine cranes work well & can be used for other things as can a winch / pully of some sort hanging off a tree branch, rafter, balcony rail etc, etc etc .
An air duster with a 4' long tube hooked up to a compressor will do the job quite fine and also will allow you to do more useful things like clean the debris off the TOP of the deck , under the mower frame and all over the transmission.
damoore46
Check Harbor Freight.
