Checking charging coil
samson123
I have a Honda gx690r taf engine. I checked the wires coming from the charging coil and it read .4 ohm should be 0.18 -0.28. also checked the voltage it was 60v.
Is the coil bad? Any help is appreciated.
Thank yous
samson123
If you can get 60V from a mower coil, patient it.
To get that high you would need to be running at 7000 rpm.
samson123
Thank you for your reply. I am running
3500 .checked with 2 seperate meters. Thats the measurement.
Does that mean the coil is malfunctioning?why is there only .4
Resistance?
Thanks for any help
Samson123
