my battery light is on and the voltage gage reads a little less than 12, and when i engage the pto it goes to 10. im not sure if the altenater is gone or if there is something else that could cause this? any help would be apperciated.
Definitely not charging, check out the charging circuit. And alternator drive belt.
Look for failed inline fuses or fuse-able links.
Be sure that Both ends of Both battery cables are clean and tight.
Do Not operate the pto clutch without the charging system, you will burn out the clutch.
BTW that has a Nice 3 cylinder Kubota engine... :smile:KennyV
