Changing the gas filter in a J D LT 445
LakeRat1
I am needing to change the gas filter on my J D 445, I have located it, its inside the frame on the right hand side, is there any
trick to it, Looks like i will have to remove the deck, any short cuts Please help
Thanks
No just remove the bolt make sure you have the gas line locks I did not get them in the JD box
