Export thread
Changing fuel filter on John Deere LT-150
#1
mucksiegooma
mucksiegooma
No problem changing out the fuel filter, but what the best way to stop the fuel flow when removing the filter from the fuel lines. Should a person loosen the fuel cap and or clamp the fuel line that come from the tank? The gas flows like Old Faithful!
Please advise.
Regards,
#2
cpurvis
cpurvis
Clamp it.
While you're at it, install a fuel shut off valve and you'll never have the problem again.
#3
mucksiegooma
mucksiegooma
Clamp it.
I thought about that but there isn't much hose coming from under the frame into the engine compartment. I will have to
see what gives. Thank you for your reply. Mucho appreciated!
