I have a 2004 Simplicity Zero-Turn, Model 1694454, and would like to adjust the height setting higher, to any extent possible. I currently have the deck lift/cutting height level raised to the fullest point. Anyone able to tell me if this can be done, hopefully by myself. Many thanks. Larry
Thanks, Mechanic Mark...I think. You referred me to my manual, whichI still have. While no specific mention is made of making adjustments for cutting my grass at a taller height, I suppose I might can figure how to raise the deck, equally front, rear and sides, thereby giving me some additional height...the max yet to be determined. I was hoping someone knew the max, if any at all, I might be able to raise the deck to accomplish some gain. Larry
