CH22, Oil filter base o-ring
ole20
Need to replace o-ring under oil filter base, can anyone tell me what is needed to remove.
Kohler CH22QS
Luffydog
Remove the oil filter and that threaded stud that the oil filter screws into has a hole which takes a Allen wrench to remove. Might have to drain oil.
7394
Or Tip the mower to get the filter the highest point.
