I want to remove my mower carb so that I can clean it. This is a Victa V40 engine as shown in the picture.
I remove the air filter housing, and this exposes the carb plus the gasket. But the carburetor is sitting on 2 long bolts, which don't appear to be removable. I can't disconnect the throttle cables. It normally requires the carburetor to be rotated to remove them.
If I pull the carburetor out from the bolts it tightens the cables and so it doesn't want to come off like that.
What can I do to remove it without breaking the throttle cables?
I have pointed out one of the bolts here,
