I am looking for some answers to common issues with carburetors. Here is my situation:
1. Fuel getting to bowl.
2. Runs fine when spraying carb cleaner directly into the carb.
3. Has good compression (100psi).
4. Fuel just wont move from the bowl up through the tube into the engine.
I took it apart, had clear openings through the main jet as well as the other jet with a long tube attached to it on top of the carb (not sure what its called)
