Carburator
rocky4
Has anyone had a problem with the carburetor on murray riding mower leaking gas at the plastic connector at the carburetor
where the line connects? I have one that the plastic cracked and lets gas leak. I cannot find that item on the parts list.
Is there any way to replace the connector with something else ? Thanks for any suggestions
reynoldston
Good place to start is with a engine brand and model. Part should be replaceable.
rocky4
This is a Brigs & Stratton engine, Model 313707 0126-E1 17.5 HP. carb is Walbro. If you look up parts for this engine, it does not show the connection for the fuel line.
Thanks for replying
Part number 692317 is probably what you are looking for. It is a plastic/brass combination that presses into the carb. It has to be pressed in, can't be turned because it will break the plastic loose from the brass.
rocky4
Thanks for the part number. It is what I need.
