Engine model:123K02-0193-E1
Primer button type carb
I've replaced the float, needle valve, and the needle valve seat using all B&S genuine parts. From bench testing everything looks great; I test that everything seals right on the bench by turning the carb upside down and drawing a 5psi vacuum on the fuel inlet and it holds steady.
After this, I start to notice problems
1) The float doesn't sit level, no matter how far I push the seat down beforehand. It's not overly tilted like "\", but it is clearly noticeable
2)I can reinstall everything to the lawnmower and run it a few minutes and there's no leaks, but when I come back maybe an hour later the mower won't start and I start to get a steady stream of fuel leaking out the gold tube that sprays fuel after priming
3) The stream of fuel from the tube leaks worse when the gas cap is removed
