Replaced carb & plug cleaned gas tank-will only start & run with starting fluid
J jhm Forum Newbie Joined Jul 1, 2017 Threads 2 Messages 4 Oct 8, 2023 / carb problem-5 1/2 hp briggs & stratten #1 Replaced carb & plug cleaned gas tank-will only start & run with starting fluid
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 65 Messages 24,995 Oct 9, 2023 / carb problem-5 1/2 hp briggs & stratten #2 Wrong carb, defective carb bought off Scamazon or Evilpay blocked fuel line IF you want specific help we need the model type & code of the engine There were quite a few different carbs used on these engines
