Carb. Linkage and springs for Husqvarna yth24v48 with b&s vtwin
Harryboom
  • / Carb. Linkage and springs for Husqvarna yth24v48 with b&s vtwin
Forgot how to re-attach linkage and springs
Scrubcadet10
Moderator
Staff member
Will need engine model information
Briggs and Stratton Engines model and type locator
shrinerguy
24 hp briggs and stratton v twin model 44n877 group 0003g1. Took carbs off to rebuild, and didnt pay enough attention on linkage hookups. Especially the springs, like choke return spring, where does it attach? I think I figured out the rest but would like to verify all the linkage.
Billrb
Harry, did you ever get a resolution on this? I have the same issue with the same carburetor, I'm looking for pictures of the linkages. Thanks
Erbid
Here are the pictures I took on the way in. Not comprehensive but got my v-twin w 2bbl carb running well once after a carb clean and again after a replace. The throttle/choke control connects to the bottom hole on the disk below the carb (which seems to have a place to attach it for frversed function).
Erbid
davis2
Your cellphone camera is your friend on that stuff.
Boomslayer
Erbid
Do you have pictures of the throttle springs below the carb?
