Can't push or pull yardman riders
hrdman2luv
I have some older model yardman mowers that I thought I'd fix up and sell. None of them are running yet. But I noticed when I was loading them into the trailer, that when I try to push them, one wheel turns one way, and the other tries to turn the opposite way.
The release lever that sticks up from the center is in the right position. On another, the lever stick out the back. Anyways, regardless of their position, in or out, the wheels still spin the opposite direction.
I'm guessing, that because all 4 of them, have the same problem, that either I'm not doing something right. Or this is a common problem.
I can't move them into the shop, or anywhere for that matter, until I solve this.
This isn't the actual picture. But it's almost identical to this.
NorthBama
the brake disk may be stuck if they have been sitting up for some time
hrdman2luv
That's what I was thinking at first. But when I jacked the rear end up, and turned on of the wheels, the other turned the opposite way. So, it can't be the brakes, because they turn freely. Just in opposite directions.
SeniorCitizen
Incorrect, that's not how it works. The brake rotor drops out of the picture with both rear wheels up.
This is how perfectly good tractors are purchased at auction for about 15 -25 bucks. Both wheels slide so the differential must be locked up. Usually not so but the brake is stuck.
hrdman2luv
I guess I'm not following you. If the diffs were all locked up, then they wouldn't turn at all, would they? All of these, turn freely. Just in opposite directions (when they're off the ground).
I pull the release lever out. The clutch/brake peddle isn't pressed. And still one tire spins one way. And the other one spins the other way.
If you're saying they're locked together, then there must be something in there, that's not releasing, when I push the release lever.
I'll make a video of it later and post it.
SeniorCitizen
I didn't say differentials are locked together. Yours is a standard differential and is not locked together. "Detroit Lockers" are locked together but not yours.
reynoldston
The differential is working just fine and doing what is designed to do. The differential sit inside the ring and pinion which isn't turning. This means that the problem lies in the transmission or brake system. So I agree with NorthBama check the brakes first.
NorthBama
Don't know what transmission you have but look under the right back wheel for a brake disk with a 1/2 nut loosen off on brake nut so disk can spin freely
SeniorCitizen
May as well get puckered up to spend some time in this area if the spline / key / rotor bore, is rusted to the shaft. The rotor must slide on the shaft with very little pressure or it ain't gonna work right.
Boobala
These pics ..may help to see... what Bama is referring to ... ( I hope )
yours may be different...???
