cannot engage the blades
When the dash lever is fully forward, is there still a lot of slop in the belt? Possibly a worn belt and/or a weak spring on the cable that attaches to the tension pulley. You wouldn't happen to have the model number, would ya? A tag under the seat.
Got the problem solved, the belt slipped off the pulley, and the tension pulley was sticking.....reset the belt and oiled the tension pulley... working fine..thank you all for your interest
Islandboy
