Export thread
cadet 1811 transaxle sunstrand? Fluid?
#1
M
miraclewhip
Is transaxle a sunstrand? What fluid is specified ?How do I drain and purge system before replacement with correct fluid?
#2
R
If would definitely help us help you if you would provide us with the model and serial numbers of your unit. Knowing this would tell us exactly which transaxle you have and maybe even find a manual. Without we’re only giving you our best guess.
#3
M
mechanic mark
https://www.ebay.com/i/132949338162?chn=ps
you may want to purchase this manual if you're making repairs
#4
M
miraclewhip
Thanks for reply.Tag on tractor frame model149-660-100. Serial #000782509.Transmission has two ported hydro-relief valves on top which have just been replaced.Now I need to drain and replace old fluid and filter.
