Hi Everyone. Just sitting here thinking about my 2 BS engine I have worked on. One 19.5 an other 18.5. Each one had blowen a head gasket. The 19.5 on the JD would you’d run until it got operating temp. then starting to smoke, back fire an cut off. The 18.5 would run but use oil an smoke. What my question is way did the 18.5 on the Troy mower run enough to use an the 19.5 on the JD wouldn’t. I did not think the head gasket was bad on the 18.5 Troy because it did run but smoke. That is when I asked you guys for help.
z
