brigs quantum boggs down.
exotion
hi. My briggs quantum is old and used up not sure about serial number there is a number stamed next to exhaust
125k02 - 0189 - e1 05020357
Manual says series 120000
Anyway I have always kept on maintenance with frequent oil changes every 50 hrs or so. Air filter is blown out weekly and replaced anually no debris on this engine even under shroud or gas tank. But its like it just runs low on power when its under load. It gas a heavy gator blade I realize its heavier but I never expected this much power loss not entirely sure where to start you can manually open choke and hear the power and when you wedge a stick to keep wot while working it still loses power. I only tryed this to help diagnose.
Any ideas
scott47429
did the problem start when you put the new gator blade on if so put the old one back on and see if it fixes the problem
exotion
No its kinda always done it. The gator blade made it worse I would like to keep using it because I really like it and I spent a lot of moneys on it
scott47429
yeah there nice but they are heavy and if its to much for the mower to handle then you may have to take it off
exotion
Even without it it boggs down almost to a point of not being able to use it. This is my mulcher mower the super recyclers are designed very well for this if I could just get the power for it..... shame on toro for using briggs.
scott47429
yeah i like the Honda and the Kawasaki engines but i do sell more briggs then anything its what my customers want and i wont put a Thcumseh out to sell anymore
Carscw
I did a test on 4 yards I cut each yard twice with factory blades then each twice with gator blades.
I side discharge always. I had less engine bog down with the gator blades.
I like the cut of the factory blades better but the gator blades last twice as long and they are only $4 more than factory blades
(( racing is the only sport that you need two balls ))
exotion
I would really like some advice another thing I am considering is swapping on a harbor freight honda clone. like I said this toro is beautifully designed the personal pace is easy to maneuver the wheels are nice with ball bearings and zerks. The deck design has a couple plastic triangles to push clippings back down the blade guard has wings to help push clippings into the triangles and with the gator blade its nearly perfect its really just has a disappointing amount of power.
exotion
I love all the helpful sugestions and useful comments
exotion
Not that anyone cares but. I added throttle control from a different briggs same style just had a throttle. New plug, changed oil, new airfilter and prefilter and just put it to test so far so good.
