Briggs & Stratton won't prime
Status
Not open for further replies.
pugaltitude
It will be a dry primer so will use air to push fuel up main jet.
The air filter backing plate is not sealing against the carb.
The air filter backing plate can be distorted so you may need a new one but usually just put more gaskets on to seal the gap.
Mike88se
Thanks. Yes, a dry primer. I didn't have an extra gasket so I made one. Was a PITA to make but looks good, hope one extra is enough. Much obliged ;)
bwdbrn1
The gaskets are inexpensive so I'd recommend getting a couple of the genuine article for the Briggs and Stratton engine you have. Next, snug the bolts that hold the air cleaner base up, but don't go Magilla Gorilla on them. That's what causes those bases to warp and fail to seal properly.
Mike88se
Hey :) I was looking at the carb and I don't see any way it will prime. If you look at the pic there are 2 holes in the carb about where the red dots are. I was thinking the primer pushed air through one of those but neither is even close to being where that would happen. I looked closer at the car and here is a plugged hole where the green dot is. That seems to be where any priming action would happen. That bulb is never going to push any air through there.
pugaltitude
Yes the green hole is where the priming happens.
I assume its blocked with dirt?
If the engine was to start with a choke instead of primer then the hole would be
blocked completely (not drilled out)
Mike88se
It is blocked completely... there was a bit of browning something...not dirt really... I scraped that out and underneath it's metal. There is a white thing on top with detentes that is on the shaft of the choke plate. I can move it manually but it isn't connected to any springs or rods.
That hole should be connected directly to the float bowl. If you take compressed air and blow lightly into the hole and watch to see if fuel is pumped into the carb throat. No fuel means you will have to remove the carb and give it a 24 hour bath, to open that passageway. Can you provide a picture of the front of the carb?
Mike88se
I can get a pic later but a bath isn't going to open the hole ...there is no hole really. Under the brown stuff is just metal. I probed at it with a pik to get the brown stuff out and underneath is just metal.
Mike88se
I could probably drill a hole right? If I was very very careful ;)
Status
