Old fiddler
- Aug 2, 2023
- 3
- 31
My 32 year old lawn tractor finally blew up and I am replacing the 12.5 hp Briggs that had no voltage regulator with a 28P777 0641 A1 14 hp Briggs that has a voltage regulator.
1) Do I simply hook the red wire on the regulator to power off the switch? It is a 2 wire voltage regulator if it makes a difference
2) I need the configuration for the fuel lines off the engine mounted fuel pump with 3 outlets on it as well
3) how is the fuel solenoid wired? Is it white (or grey?)to power and black to ground?
If you can point me towards a service manual or post the diagrams, I would appreciate it.
Thank you
Thank you
