I have some issue with oil filter thread rod which oil filter screw in. When I placed oil filter that rod broke, forced too much. Is there any way to fix this instead of replacing whole engine or oil sump. Whole block is aluminum. Weld or I can use JB weld or other easy way?
Thank you
Don't think there is any easy fix for that. In 70 years of working with small engines I have never seen that. My first impulse would be to drill and thread the broken off stud. Sump will have to be removed to ensure cuttings are cleaned out. Some people use heavy grease on drill bit and threading tap to capture cuttings, I wouldn't trust that. I don't know what the threads are but an adapter will likely have to be custom machined. Alignment will be critical so filter will seal. JB Weld will NOT hold that.
The center part of the hole from the picture will come out? Look like different material, if that thing come out I can buy this oil filter adapter and screw in. https://www.summitracing.com/parts/aaf-all92003/overview/
I think they have all kind of sizes.
The hole is steel and should thread out,( Gees my English teacher would have liked that sentence ).
IT will be difficult to grab but there should be a very thin hex at its base if it is removable.
Some are locktited in so the sump will need to be warmed to remove it .
The entire sump is not particularly expensive and as previously mentioned you should take it off for cleaning so you are going to up for a new gasket & oil seal in any case.
