Briggs & Stratton ID-ing Help
Gearheadmike
So i just picked up a International 382 Cadet mower with a B&S research shows these are supposed to be 11hp but to me it looks like a 8hp and
When i look up parts and place the model number in nothing shows up.
# is 190707-0799-01 73062111
try 190707-0799-99 instead. some of the old engines use a generic trim number. 19 series engines are normally 8 hp. The 11 hp should be a 23 series if I remember correctly.
19 series are a 8 HP .... What parts are you looking for ???? If you are searching for a part number in the Briggs site then the model number only not the Type numbers..... Unless you are looking for the parts manual....
Let us know Mon Ami ~!~!
If you are looking up the manual on the Briggs site then only the Model and type are typed in.. Not the - 01 or - 99
Just 190707 0799 with no dash.....
Gearheadmike
well 8hp and year of 1973 that tells me it's not original seeing machine yrs were 79-81
I also just pulled head do to low compression and found the exh valve seat hanging out. After cleaning i seen previous repair attempts to peen the seat but failed. Along with the pcv breather assembly was drilled out??? I guess ill look for a modern ohv engine. Thanks for info tho!
Mike do you have the points and condenser on that engine ?? Those are good engines to rebuild if nobody did toooo much other rigging to it.............
