Briggs & Stratton 17.5 hp Twin II torque specs
BlaneR
I have a B&S 17.5 Twin II (horizontally opposed cylinders) that I'm sorta rebuilding after the engine locked up on the upper connecting rod galled up on the crankshaft (due to low oil and a hill). I'm ready to put the thing back together, but I don't have a manual, and the place I got the parts couldn't find the torque specs. I need the specs for the connecting rod and heads. And, if you have the manual in electronic form and don't mind sharing, I'd be most thankful.
I appreciate any help you can give.
Peace,
Blane
Hi BlaneR
I just looked on the internet and do a engine search for Briggs & Stratton engine specs there is quite a few sites i looked at the top one and they asked for model number so if you know that you should be able to find specs for that engine. They have manual to on there. Good luck
